sloman2001's avatar
sloman2001
Aqua Hot Questions...
for a MH "wanna be".
We are considering a coach with the Aqua Hot system (I have read the operating manual) and are trying to find out a little more about it, so thank you in advance for any responses. Without laying out a litany of questions, here are 5 questions about the Aqua Hot system I’m seeking clarification on.
Can you use the AH hot water system when camping in sub 32 degree conditions (maybe 25 degrees), or must you always winterize if it is going to get below freezing? We often camp in colder weather, so I just want to know if I need to winterize at the slightest chance of 32 and below. (not asking about the coach heating, but the water heating system)
Generally, what constitutes the bay heating system (maybe coach specific)? Do I need to ask the particular dealer?
To winterize, I have read you cannot merely blow out the lines, but you must use anti-freeze. I am just curious as to why?
If you are going to be driving through conditions below 32 degree’s and are using the engine to heat the rig, do you still need to winterize your lines?
For heating only (not for the continuous water supply) to what general outside temperature will Aqua Hot’s use of the 120 VAC burner be sufficient before the diesel burner kicks in or will electric alone provide enough heat? In reading the operating instructions, it sounds like the electric element alone will heat the anti-freeze solution for heating. But it also sounds like you need the diesel burner, so I am just a little confused. Any clarification here would be helpful.
Maybe these sound a little dumb, so thanks for your patience. Thanks again for your time!
Tom
  • ct1964ups wrote:
    it is a great system and this is what I did so far....
    I drained all the domestic water from the lines....I disconnected the water lines from the pump....and opened both low point drains...BUT I DID NOT RUN THE ANTI FREEZE THRU THE LINES
    now my question...CAN I STILL RUN THE AQUA HOT SYSTEM FOR HEAT USING EITHER THE DIESEL OR THE ELECT.....????
    Thanks..Chuck
    When I asked that question of Roger Burke on the Aqua Hot forum, he said yes. The Aqua Hot system is filled with a boiler coolant and that is what provides the heat to your heat exchangers in the coach. So, even if you 'winterized' you can still use the AH for heat.
    Regarding Winterization, both Aqua Hot and Roger Burke strongly advise not to rely on just draining the domestic water and using air to blow out the water lines. The coiled domestic water lines in the Aqua Hot need to be winterized by pumping RV antifreeze (the pink stuff) through the system. Merely blowing out the water lines may leave enough water in the Aqua Hot coils for freezing and bursting. If that occurs, the repair is very expensive.
  • Hjudge49 wrote:
    Chuck, you can still use the Aqua Hot for heat. The boiler is still full of fluid, and the fact that the domestic water coil is empty (or partialy empty) will not hurt it. It would actually be better for you to keep it turned on, since opening the low point drains doesn't really get all the water out of the coils. I never winterize my coach because I live in Florida, but when it even thinks about freezing, I keep mine turned on electric to make sure it doesn't freeze. If it does, it's a replace, not repair situtation.
    Hey guys...both of you ..for the quick answer.....Chuck
  • Chuck,
    If you are going to leave the Aqua-Hot running (either electric or diesel), you will be fine with what you did. HOWEVER, if you shut it down and it freezes, you'll be in big trouble, without proper winterization with the pink stuff. If the internal coils freeze and burst, which will happen quite easily if allowed to freeze, the unit CANNOT be repaired. You'll be looking at a $10,000 bill for a new unit.
  • NOT running antifreeze thru the hot water coils is a bad idea if you will depend on leaving the unit plugged in and using the 120 or diesel to keep it hot. What happens if you have a major storm and you lose power for a few days??? The system shuts down and then will slowly get cold and then freeze. We just had this type storm in the DFW area of Texas and 10's of thousands were without power for up to 4 days and the temps we had would have frozen the water coil in a Aqua Hot unit. Doug
  • paulcardoza wrote:
    Chuck,
    We also have it in an enclosed insulated garage that is attached to the house....2 walls use the house walls.....and one wall is along another 40 ft garage.....so only the door really faces the outside.....but neither garage is heated.....Chuck
