Ok so I have a 96 tiffan & the autopark light is on & the buzzer is sounding. It doesn't matter if it's in park or any other gear or if the key is on or just in the run position. I have checked the f...
Where is the transmission fluid leaking from? Grey switch, green switch, actuator? If you remove the steel side plate you can see inside where the fluid is leaking from. Like the previous poster I have replaced both switches of 11 years and now carry spares.
