olfarmer
Jan 23, 2013Explorer II
Auto Park
Just curious, I have been reading about all the problems with Auto Park. Is there anyone out there that has not had any problems on a motorhome that is equipped with Auto Park? I bought the green swi...
olfarmer wrote:NORM WADDELL wrote:
AutoPark applies a parking brake by applying
a band brake around the drive shaft. When that switch
fails, the drive shaft is LOCKED......no can move R V.
A knowledeable person can get under the RV and
release that brake, and THEN wheel blocking when parked
is required, until the system is repaired.
Beentheredonethat.
Yes, I have read about how to disable it, and crawled under and located the pin to pull. I was just wondering if ALL auto parks fail or if some work fine for most of the life of the vehicle. I have read quite a bit about the various problems and remedies. I guess I would like to know if the failure rate is 100%--50%--25% or??????
