NewbRVer's avatar
NewbRVer
Axle shafts
Hello, I just bought an 83 Pace Arrow. It was towed here and the axle shafts were pulled out of it.
I went to put them back in. The first one went in without any issue, a bit of wiggling back and forth to get it to slide in.
The second one, refuses to... I've spent an hour turning it a tooth at a time trying to get it to slide in but it just won't.
Am I missing something? Should I put it in neutral and try to shift it a bit to get it to line up? Something else?
Please help lol
    Please help lol
    Looks as though you're getting plenty of help with ideas here, so now, I'm assuming that the axles were pulled, so it could be towed and it's also a Chevy. Now, I never could understand why someone would take that option over disconnecting the drive-shaft and maybe someone can offer some insight into that, before someone else finds themselves in the same situation.
  • Ivylog's avatar
    Ivylog
    Explorer III
    You do not need to jack it up you just need to move the axle shaft back-and-forth as you hold the splined end up. I'd say you lucked out on the first one going in so easily and this one is making up for it.
  • I should add... its to the point that the back of the gears are touching the plate, it's just that last mesh that I can't hit.
    I point this out because with it still about 6 inches out, you have to get the end (inside) up a bit to get it to go further and that was no problem.
    It's just getting the teeth to slide into their spots that isn't happening.
  • lol, too late on the crazy part... (I already reached the 'kick it' stage... didn't help lol)
    As for the getting it off the ground. Apparently, I don't have a jack for it either... there were some jack stands to put under it after lifting it, just nothing to lift it with first.
  • NewbRVer.....First, you need to take a break from it for a few minutes so it doesn't make you crazy. You need to get both rear wheels off of the ground. Have someone turn the other side while you try to insert the one that doesn't want to go. Use vicegrips as suggested or something to give you some leverage to tilt the gear end up as you try to insert it.
  • They are the original ones and there is no damage on them in any way.
    I want to be clear, I have zero clue what I'm doing here... It's parked in the driveway where it was towed to, still in park, wheels blocked.
    So, if I was supposed to do something that any idiot should know, I likely didn't do it lol
  • We would assume that it's the original axles or at least the axles that were in it at the time it was disassembled. I guess I would check the spline count or any damage to the splines. Maybe one of the axles was replaced and is now not the correct one? Check the end closely for even one ding in a tooth.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Should slide back in. On a heavy shaft I've had to put a pair of vise grips on the bolt flange to help lift the splined end up.
