Toot_Mc's avatar
Toot_Mc
Bad fuel
Chasses E-450 Ford
Filled fuel tank but could get no recite at fuel pump...!!! attendant tells me had 3 inches of rain day before and pumps were so wet recite machine not working in pumps. Drive about 5 miles Engine check light comes on!!! Stop check fuel cap to see if loose. does not help. Check fluid levels everything OK. Drive a short distance everything OK. Guys tells me fault code will go off after three engine starts if nothing wrong.
Code still on a couple days later pull into garage to get code read. Folks I got a tank of bad fuel. Put New filter in and Motor Home runs great.
My question? One guy tells me i need to drop tank and put in new pump. Another mechanic says pump ok if code light not coming on because if pump damaged it would not pump correct pressure and code light would show.
Have any of you run into this problem??? I have driven about 1200 miles sense changing filter and have not had a problem or trouble light.
