- jornExplorerSafe-T-Plus doesn't *appear* to offer a unit for a E450-based Class C.
- gotsmartExplorer
poker5150 wrote:
Since you are going to install a new damper, why dont you go with a coilover system like the Roadmaster Reflex steering stabilizer? It dampens and stabilizes
I went with the Safe-T-Plus, because the spring is enclosed within the casing. - Kit_CarsonExplorer
fordman17 wrote:
Yes, it is a direct replacement for the OEM dampner. I replaced mine with the Bilstein unit last year. Major difference noticed.
To replace the original steering damper with a Bilstein will it mount same as the original on the e450 ? - fordman17Explorer
Ok i'll have a look at that,i have seen it talked about on here,thanks - poker5150ExplorerSince you are going to install a new damper, why dont you go with a coilover system like the Roadmaster Reflex steering stabilizer? It dampens and stabilizes
38,771 PostsLatest Activity: Apr 15, 2026
