catsgalore wrote:
We have a 1999 Fleetwood class A motor home and once in awhile we tow our Toyota Tacoma truck. We do not have a supplement braking system for the tow vehicle is this a must? I looked into a few of them and there quite expensive with installation.
Ignoring state law.. YES IT IS A MUST, Per one company a proper braking system can cut your skid distance as much as 30%, If you should have the bad luck to rear end someone.. That's the difference between "OPPS" and Reckless driving practice.
Several systems: If you tow often. the Ready Brake or Blue-Ox Auto-stop are surge brake systems, these use a cable and levers so that when your towed pushes against the motor home the towed's breakes are applied. Purportionally, Progressively, all automatically. The system is nearly 100% invisible when not towing (Small bracket on brake arm).
If your motor home is a diesel, and has air brakes, ANd if the slave unit fits on the towed (Will not fit all) M&G makes an air powered system. This one is 100% invisible to the driver of the towed when it is not being towed, NOTHING at all shows up inside the cockpit.
The above systems use no electrical power save for brake lights may com on with the Ready Brake/Auto-Stop.
There are some air powered pedal pushers as well, this system mounts a cylinder under the driver's seat and you have to hook it to the pedal, pumping the brakes several times when you hook up.
Now we get to electrically operated systems.
US-Gear Unified Brake Decelerator offers the most control over the towed brakes of any system made, This system the only visible part is the bracket like on the top listing. There is also a solenoid system but it is normally under the driver's seat (I put mine elsewhere but still out of sight). This system eats battery power, but gets it from the motor home.
Invisible Brake.. This one works all automatically.. Again you see only the bracket,, No hookup at all (Works off the tow light system) eats power but again gets it from the Motor home.
There are a number of systems that mount under the dash, like the above just the bracket and possibly a switch, showing. These do not however re-charge the towed battery.. Thus I dis-trust them (As the towed battery ages they can fail).
And finally we find the box in the driver's seat systems (Brake Buddy/Even Brake/ and more) these need to be installed by you every time you tow, Mistakes can happen, and they eat battery power with no way to replace it (See last paragraph) Plus you have this big, attractive to thieves box that you have to stow when NOT towing.
