dgtjhatt's avatar
dgtjhatt
Car Dolly
Just bought our first Motor Home. She is a beauty.2007 Joyco Grayhawk33SS.We bought it from a private party and we could not believe it when we saw them drive out of an RV garage where it had spent most of it's life. Then we saw the odometer and it read 7,500. It still has the plastic that was on the cab carpet from the factory and a tag hanging from the dash that tells about the air bags. We took one look and said we will take it. Our Ford Escape can't be towed with all four tires on the ground so we will have to use a car dolly. I would like to hear the good, bad, and the ugly about your experiences with car dollies.
Thanks,
Don
  • There a couple different types of tow dollies. I fell the the type that Demco makes is by far the best type. I don't know if that type is made by any others. There's one less pivot point. It tows like a 4 wheel dolly, where the front wheels pivot.
  • Another advantage I forgot to mention is it is the cheapest way to go, if you can buy a clean used dolly, which is not hard to do.
    You can usually sell it for about what you paid for it.
    A trans pump is $1000 and up.
    Tow bar, baseplate, brakes, etc is several thousand.
  • It's added weight. A pain to store/fit at the campsite. You might check to see if they make a transmission pump for your Escape that would enable 4 down. If I we're to get a dolly, it would be a Demco that folds up two ways.
  • We did it a few years.
    The negatives are loading it in the rain; tire spinning.
    Dirtier.
    A toad tracks inside the RV footprint. Dolly can hit gas pumps, etc.
    Unhooking for overnight stay.
    A few parks won’t let you keep it at your site, so unload, drop off, drive both vehicles, etc.
    Extra set of tires and bearings.
    If you’re going somewhere for a week or longer, no big deal.
    If you’re traveling everyday, not so much..
    I’ll never go back.
  • We also have a Ford Escape that can't be towed. After looking at dollies just a little bit, I decided I didn't want anything to do with one and bought a used Jeep. I installed all of the necessary equipment myself.
    Bill
  • They work very well . The big advantages you can change cars and you can still use the same tow dolly . They have their own breaks system so it doesn’t require a lot of effort on that part . You need to be sure and check the tire tiedowns after the 1st mile or two after that they stay tight pretty well . I use the actme tow dolly and it does a great job I’ve never had any problems whatsoever
