JaxDad wrote:
elargentino wrote:
Just had the converter stolen while rig was in storage. We had trouble finding a replacement so we just welded in a straight pipe, which works great except the engine check light is on all the time now because the O2 sensors aren't connected.
The issue is not just the light on, without input from the O2 sensors the ECM will go into ‘default’ mode and the air / fuel mixture will be way off (far too rich) what it should be.
If the O2 sensor to the rear of the converter is the one that's not connected, it only reports to the ECM, if the converter is working or not and had no effect on the tune of the engine. If the O2 sensor forward of the converter is not connected, then you post is correct.
Richard
