Goldencrazy's avatar
Goldencrazy
change tires from 19 to 22
I notice that people change the tire diameter on cars frequently and in fact we increased the diameter of our tires by 1 inch on our Smart Car and some folks increased by 2 inches. That is all the wheel wells will tolerate. For me the tires were also wider. Made for better ride and stability. I understand that coaches with the 22 inch tires ride better. I seem to have plenty of wheel well room on my Vista 30T. Why shouldn't I consider increasing the diameter when time to change tires. I understand that width might be a problem if I increased because of distance between duals. Any thoughts?
  • Not sure what trans you have, but changing tire size can really mess up the shift points. I do know someone who went up in diameter with the Allison 6 speed and his shifting was really messed up. Of course transmissions can be reprogrammed.
  • Surely you know that you can't simply change the diameter of the tire without changing wheels as well, and that is going to be a really expensive change with very little payback.
    As for the larger tires riding better, that is debatable. It may be true on a chassis designed for the larger and heavier wheel and tire, but adding them to your light and short chassis could just turn it from a "Bread Truck" ride to that of a "Log Wagon".
    I have an older 16" wheel coach and I hear folks with the 19.5s and the 22.5s with the same complaints that I have.
    Weigh your coach and set the right tire pressures.
  • On Michelin Tires website they have a chart on what tire that you can move up or down to.
