trop-a-cal
Jan 26, 2015Explorer
Always check contacts first. Clean positive and negative terminals and ground connection. Do this with no power drawn or being generated or shore power. Many RV's suffer from corroded and or loose connections due to moisture and road vibrations. Of course the water levels have to be right in batteries and only used distilled water to bring them to level. No matter how good grounds look always disconnect and wire brush the contact points on chassis and wires, then reconnect and spray with battery terminal anti corrosion.
38,708 PostsLatest Activity: Mar 05, 2025
