DrewE wrote:
Ivylog wrote:
Executive wrote:
I average 42mpg with my setup....your mileage may vary.
32 with the car and 10 with the coach...:B...Dennis
Dennis's point is that there is more to this than just the MH although his average is actually 22 MPG. We usually put as many miles on our car as the MH and I recently bought a car that gets 44 plus the 7 for the MH divided by 2 = 25.5 average.
I can get 10 mpg with my heavy DP (44k lbs) but 45 MPH is too slow for most roads. A MPG without the speed you drive and to a lesser degree your weight is meaningless. My 7 is at 65-67. From the many posts over the years on MPG I'd say a 5.9 Cummins will average 10 mpg at 60 mph.
The average of two ratios is not generally the mean of their values. If you drive 50 miles at 50 mph and 50 miles at 10 mph, your average speed is not 25 mph, but 16.6 mph (100 miles / 6 hours). In your case, with equal distances at 44 mpg and 7 mpg, your average fuel milage is about 12.1 mpg.
Since you are correctly pointing out that the average of two ratios is no usually the mean of the two ratios, I will point out that the mean of 50 and 10, in your example is 30, not 25.
As far as expected mileage, we just finished a 7000 mile trip. According to the computer, we averaged 8.6 mpg. But the computer is generous. Dividing the number of gallons used into the miles driven produces an average of 7.925. But that is misleading, also; we had almost 90 hours of generator usage.
Allowing 1/2 gallon of diesel fuel per hour of generator usage, the average miles driving per gallon of fuel become 8.34.
Tom
