rgatijnet1 wrote:
Find the floor plan that works the best. Both gas and diesel coaches will get you over the mountain and to your destination. If you are the average RV owner that puts about 5000 miles a year on your rig, the cost of fuel should be way down on your list. If you need a 10K towing capacity, then there are NO gas Class A coaches that have this capacity so that makes your choice pretty easy. If you can get by with a 5K towing capacity, then your choices are open. Floor plan always it more important than anything else with an RV. You will spend more time living and sleeping in your coach than you will driving it.
Exactly the point there - If you are planning to tow the Ram, forget gas, not going to happen. Most gas class A's are in the 4 - 5,000 pound range for towing, based on total weight. But, I will say this - a gas coach is a lot less expensive to operate and maintain than a diesel. Around here, an oil change will set you back $500. Air filters, another $200, etc, etc. Radiators are $5 to $10K depending on model. We looked hard at DP's and after doing a total evaluation, went with the gasser ad=nd are very pleased wit the performance towing and it does fine over mountain passes and going down. Length can be an issue in some state and national parks as often they will state a size limit of 35 feet. Not always the case, but just something to be aware of. Good luck on your search - and the floor plan tends to become a very important item in the checklist.
