LOG wrote:
For all the members that are somehow missed the point of my original post, please be assured that you do not have to block my post. I do not respond to questions that do not directly apply to Class A Motorhome. That is one of the main reasons I would like to know the type of RV that a member is asking about. And, for all of the members that have not owned a Class A DP, then you really have no clue about the systems that one has. Some electronics are the same, some furnaces are the same, some air conditioners may be the same. But the generators, air bags, inverters, leveling systems, slide outs, engines, and a host of other items are not the same. I also own a Winnebago Itasca Gas Class A Motorhome. There is no comparison between the two as far as the systems go. Travel Trailers and Fifth wheels have no engine or transmission. Most do not have a generator. For sure not a diesel generator. As I said, the title of this forum is Class A Motorhomes. There are forums for travel trailers, fifth wheels, Class C and B motorhomes. I do no read those forums because I feel I would not have much to share. I only belong to two forums, this one and the Foretravel forum. I read this forum to increase my knowledge of Class A Motorhomes. I have to say that I don't gain much knowledge. I belong to this forum because I like the what Good Sam Club has to offer.
Many, if not most people on this forum have owned many different types of RV's and their knowledge base is not limited to their current RV. Most that post on here also do their own maintenance on their coaches. The varied amount of info from the members here is full of knowledge, if you just open your mind and accept it.
What we need to know from you is do you do your own work or just write a check to someone else to take care of your coach? I notice that your coach is a 10 year old 2004 model. ALL of your systems are outdated and anything you can contribute to this forum may be useless to members that have newer coaches.
If you ever break down at the side of the road, or take your coach in for any service, be sure to verify that the mechanic also owns a Class A otherwise you may not want him to touch your coach. :B
I should add that if you check at the top of the page, there are forums that deal specifically with Good Sams Club services. If that subject is what you are primarily interested in, THIS class A forum is the wrong one for you. :W
