susblum's avatar
susblum
Coleman AC. Should we upgrade to heat pump
Our 2017 Jayco has a Coleman AC. We miss the Dometic heat pump that was in our Forest River. Thinking of pulling out the AC. Any feedback on upgrading to a heatoump
Is one brand better than another? What about a heat strip. We are sucking down too much propane.
  • Heat is very relative to wattage. A good quality space heater will go a lot further than a low qual because of the distribution, fan, and overall engineering. REMEMBER though that more expensive does NOT mean better. One of my best space heaters is from the 1980's and still going today.
  • Another option may be the electric heat coil in the furnace.
    Cheap Heat. I don't know anyone that has this, but the advantage would be that it would operate continuously down to temperatures that the heat pump would not (<40 degrees), and it would circulate as well as your existing furnace to a point - they do have to slow the fan down to match the heat output.
    1. Heat Strips are NOT meant to heat an RV, Just take the chill off.
    2. Since you already have the RV wired for a RVP(Coleman) just get a RVP HP. You only have 2 choices. Dometic and RVP. Both are comparable.
    3. You will have to change the wall Tstat if you go to a Heat Pump.
    4. HOW long is your Trailer? If over 25 feet and you have 50 amp service, install the original AC in the Bedroom and install the HP in the living room. Doug
  • msturtz wrote:
    A heat pump is economical to operate and distributes even dry heat. I had them on a prior rig and really liked it. It does not use nearly as much energy as a radiant heater or strip heat.
    A Heat Pump will pull 1680 watts. I do not know of a Radiant heater for standard Household use that pulls more than 1500 watts. They use about the same energy, but the HP will distribute the Heat much better and thruout the RV unlike a Radiant heater. Doug
  • We use our heat pump along with ceramic heaters. They both have their place. That said I would not pull a working AC just to replace it with a AC/HP.
  • A heat pump is economical to operate and distributes even dry heat. I had them on a prior rig and really liked it. It does not use nearly as much energy as a radiant heater or strip heat.
    You could just buy a couple ceramic heaters it would be a lot cheaper.
    Bill
38,756 PostsLatest Activity: Sep 28, 2025
