path1
Aug 03, 2015Explorer
My limited experience is sometimes gvwr makes a difference. Not often but twice I got the wrong part because of GVWR.
When I replaced my brakes the new front brake lines wouldn't fit. Took it back and the ones they gave me had a little different fitting at top. Barley noticeable difference but a little metal tang at the top. Second trip to part store, I brought old line with me to show them the difference. Part guy look up info again and then asked me what the gvwr was (first guy did not ask for gvwr). I didn't remember what gvwr was. Stopped by Ford being it was on the way home. They did ask for gvwr or last 6 of vin. Turned out there was difference of brake lines for gvwr ratings. The one I needed (heavy duty) was out of stock and took 3 days to get in. And another time I was given the wrong size bushing for the sway bar.
Now when I go after a part, after the part guy asks for year, engine size etc I ask if he could look closely to see if there is any difference between gvwr ratings or what some part places call "heavy duty". Only has happened twice.
When I was looking at the Haynes manual at our local automotive store it said "not for commercial chassis vehicles." I am assuming that the RV is considered a commercial chassis vehicle, can anyone confirm this?
I've never seen a sticker that say commercial or not commercial on mine. Probably was at one time and now long gone. But I do have a sticker that says "not ambulance ready" or words to that effect. I asked ford part guy to explain the difference. Turns out ambulance has some different wiring and few other things, like bigger alternator and "heavy duty" blinker flasher.
If torque values are not listed in the section you are looking at, my Haynes has a page in back that gives common torque values for sizes of nuts and bolts.
If I ever do my brakes again...to include changing calipers I would spray the caliper mounting bolts with PB Blaster 3 or 4 days before and let it soak in. Mine were pretty hard to get off and required lots of force to break them lose.
Hope this helps
Hope this helps
