egh33's avatar
egh33
Correct Gap for Spark Plugs
I have been reading on a couple of RV sites and there are 3 different answers.
I 'm installing new plugs & wires on a Vortec 8.1 engine. My book says they should be gaped as per engine specs. I can not find it any where in the book that came with the coach the correct gap. This is the second set of plugs, first set was installed by a shop when the Air Ducts were installed as The coach is a Winnebago Adventure 35A With a Vortec 8.1 . The new plugs I want to install are AC Delco R44LTSM That's what the book says.
My question is do I gap them at 0.60 0.45 or 0.50
There is over 30, 000 miles on this set of plugs. I noticed on my last trip I did not have the power I did have and it would spit & spudder every once in a while. I do know it needs new wires. so while I'm at it I' just going to replace plugs& wires.
Any one know what's the correct gap??
Thanks a bunch
  • This is always one of the best sites for Workhorse 8.1L info:
    OEMYS Performance
    He says to go with .045 or .060. Don't forget to install the heat shields.
  • According to Delco, they come pre gap when made, It states not to try to re-gap.
  • Chassis year?
    And a quick search found others from 6-10 years ago with similar troubles, frequent cause was plug wires due to engine heat.
  • Mandalay Parr wrote:
    Did you search Vortec 8.1?
    Yes, I sure did. and got 3 different answers.
