3Fivers51's avatar
3Fivers51
Critters chewing tubing/wiring
I have a 2016 Greyhawk and I am still having problems with some critters chewing wires propane lines. In June of 2017 I had to repair gas hose that runs underneath to my frig., and the furnace. Also upon further checking the RV dealer found that something had been chewing wires in and around the self-leveling device. Anyway to make a long story short, I just found another propane tube chewed off. So does anyone have any ideas to fix this problem? I don't know if it is rabbits, mice, or squirrels. But I have mice traps outside on the ground by the tires, I have a live trap right underneath the propane tank. I never had this problem before I bought this Class C. My thought on this is that the 5th wheels I had an enclosure that covered most of the underneath. But it is my opinion, at least with this class c I have is that you can't completely enclose the underneath because of the drive shaft. What do the owners of class A's do? Are they different? I will appreciate any and all opinions/facts to help me through this critter problem.
Thanks,
Bill
  • I use moth balls in the voids. I use only a couple in each of the areas.
    You need to check under the rig for small openings where the vermine are getting in. Seal openings with expanding foam.
