MarcW's avatar
MarcW
Cummins ISL400 runs and quits... questions
I'm currently stuck in a RV campground with a engine that won't run.
I called and talked with the nearest Cummins service center and the tech on the phone says he thinks it's the lift pump.
The problem goes like this... After getting parked after a normal 250 mile day driving, I started the engine again later and it ran for about a minute and then quit. That was a first. I started it again and did the same thing. I got a "engine comm error" on the dash.
It repeated the same thing several times so I took a break to go on line to search the engine comm error thing to see what I could find out.
One person said that they had a similar event that was caused by a "WIF sensor", another said to disconnect the chassis batts and reset.
That was easy so I did it and the engine started and ran. I let it run long enough to come up to temp and it ran perfectly but I had to shut it down because it was getting late and I didn't want to make everybody mad.
The next morning I restarted and once again it quit, so what exactly caused it to run normally on the previous start and now go back to the problem again is unknown.
When I turn it on the lift pump runs for 30 seconds. Same amount of time every time I do it. The tech said it should run for a couple minutes.
At this point we're waiting on the lift pump and then they will make the 45 mile drive out to diagnose and hopefully fix the problem.
Anyone have any thoughts on what else might be going on? It acts like it is simply running out of fuel after it starts but the "engine communications error" sounds electrical to me.
The coach is a '07 Monaco Dynasty.
Thanks in advance for any insight you might be able to give me..... Marc
