glamisorbust
Mar 20, 2015Explorer II
I only have experience with my coach, a 1999 holiday rambler endeavor. Mine has the 5.9 24 valve cummins. I picked up the coach in august of 2014 and the air has always worked. It does blow cold and fairly hard, but I don't think you'll ever be satisfied if you're comparing it to a newer pickup truck.
The truck has a lot less room to cool, the DP has such a vast area to cool that you'll need to run the genny and roof airs to keep it cool in there if it gets up to 80 or 90 degrees. I had another gas coach with the 454 that I was dead set on getting it working properly.
I spent about $300 on new hoses, evaporator, condensor, etc. and got it charged. It did blow cold, and was a little helpful but still had to run the genny and roof air to keep it reasonable in there. Hope this helps.
38,776 PostsLatest Activity: May 14, 2026
