Cobra21
Mar 21, 2015Explorer
The dash air is to be about 20 degrees cooler the the ambient temp. inside.
So if it is 90 in the coach, then it should blow about 70. It will work its
way down as the inside temp keeps falling. Same goes for the roof top unit.
When it is 70 inside, the unit should blow around 50. When they run like this they are also pulling the humidity out which is the big thing!
Hope this helps, Brian
P.S. Some units just will not cool well depending on the sun, glass, insulation, and air leaks or quality of the build.
38,776 PostsLatest Activity: May 15, 2026
