Jim
Apr 23, 2017Explorer
The mineral oil isn't a trick. Recommended by battery users going back to Edison himself. The amount is 2 oz of mineral oil per cell. And generally you add it when your battery water is a bit low. Or you can turkey baster remove 2 oz of water/acid before adding. But with the big style batteries we RV'ers use, adding without removing any water isn't really an issue.
It works great and has been used, like I say, since wet cell batteries were invented.
What it does is whenever a bubble of gas is produced because of the chemical reaction of the acid with a lead plate, when it releases from the plate and rises to the surface of the water/acid, it runs into the mineral oil. This slows it's rise, than when it bursts, the oil reduces the amount of acid thrown into the air above the water/acid surface. This prevents most of the acid from floating out of the battery, which reduces the chemical interaction with the metals outside the battery. Reducing corrosion.
38,782 PostsLatest Activity: Sep 10, 2026
