bobm253
Oct 24, 2016Explorer
Did I almost mess up on a winterizing step?
Every year I have used the pink antifreeze with no problems. This year I decided to try using compressed air only and I think I may have dodged a bullet.
Drained fresh water tank and low point drain. Closed low point drain so the system would pressurize.
I bypassed,flushed and drained water heater.
Hooked up air compressor at 40 psi to city water inlet.
opened all faucets one at a time until only air came out then closed each faucet.
Feeling pretty good that I got all of the water out of the water lines and only needed to add antifreeze to toilet and traps.
Then I decided to double check the low point drain with the compressor running to ensure only air came out. To my surprise I released a good amount of water that had remained in the pipe.
Now I know I need to ensure that I do that last step every time or the low point drain would have surely froze and broke.
Don't remember seeing this as a last step to take but thinking about it it sure is a must do.
I'm probably going to pump antifreeze in the system anyway or am I wasting my time and money?
