milkman41
Mar 05, 2015Explorer
Difference in levelers
I have noticed that larger DP models have hydraulic levelers, less large (39 & below) have electronic levelers. Is there anything to be aware of with electronic?
VinCee wrote:
I think the reference was to stainless steel ram rods, not the whole unit. I have Lippert's hydraulic system on my coach and they had a real issue with hyd. lines being bubbled from corrosion inside the line prior to installation. IMHO Lippert products suck. So far knock on wood I've haven't had any problems. My 2000 Allegro had HWH. When it was about 8 yrs. old one seal started to leak on the left rear ram. At times it seemed like the springs for retraction were getting a bit weak but overall I prefer the HWH system from my Lippert. If you notice, a lot of the quality rigs out there like Tiffin use HWH.
Beacher wrote:
It's not so much a size of coach thing, as it is the brand of Motorhome. I have a new 35' coach that came with a modern fully hydraulic system.
Electric Systems:
- Generally have an electrical limit switch. You don't want the switch to get fouled with water/mud/gravel/sand/dirt, or it won't work.
- Independent, if one goes, the rest of the system isn't compromised.
- Chrome or painted - It may rust and requires maintenance.
Hydraulic Systems:
- Older systems have big springs to retract the pistons. You don't want gravel/sand/dirt/mud in the springs.
- Newer systems have no springs. Must become familiar with manual retract process if things stop working.
- If one leveler goes bad, (like a bad leak), the entire system may not work, (only some systems).
- Stainless Steel - carefree.
time_to_go_now wrote:Dale.Traveling wrote:
What I've always wondering about is why do the builders install the operator's panel in the driving area? I installed the panel near my slide controls mid coach. Jacks go down slides go out, slides come in jack go up.
Because I pull into a spot, set the e-brake, and push the leveler button. Then I get up and push out the slides.
When it is time to leave, my wife brings in the slides. I get into the drivers seat, start engine, let it warm up a bit, retract the levelers, and drive away.
Would be odd not to have the leveler control panel within drivers reach.
