lacofdfireman
Aug 12, 2016Explorer
Do I need new steps? Help me decide
So we have a Coachstep 3 step on our 07 Georgetown 350DS. The steps have started to be real sluggish on retraction. Extension they do fine. Also on the very bottom step if you step on the left corner they will basically extend all the way to the ground. If you step on the right side it remains the same. I've lubed it well and replaced a few bonze bushings in the sides but it hasn't helped. Just wondering if I should just replace these as I'm afraid I'm going to show up somewhere and they will not work.
My biggest problem is I can't get it diagnosed anywhere local because they are 2-3 weeks out to even take a look. Is this something I can do on my own? I called Lippert and they told me I need to figure out what bolt pattern I have on my steps currently for mounting but I have no idea what they mean by 8"x22 or 8'x26
Lastly I'm wondering if I do swap them out if I can go from a 3 step to a 2 step? The current 3 step the 3rd step is basically on the ground. And if we pull into anywhere there is a curb out steps won't come out. It's kinda a PITA..
What should I do?
What should I do?
