Hula
Apr 30, 2016Explorer
Do I need to carry spare tire?
Is there a valid reason to carry the extra weight of spare tire? Will roadside assistance show up with tire mounted to wheel and then change it? There is no way I could change it myself.
bluwtr49 wrote:Rog & Nan wrote:
Our unit is 20 years old and it came with a spare tire mounted on a rim. Never had a flat until 8 years old and had tires replaced. First trip out front right tire went down on a county road in southern Indiana. Tow truck from west side of Louisvlle was almost 2 hours to arrive. He spent an hour trying to locate our size tire and rim even though we told him we had both. His experience told him it was probably old and not in good shape. He could not find a tire so brought his big rig to tow us in! To his surprise DH is a maintenance freak thus tire was in great shape and ready to go. We had destroyed the rim trying to get to the side of the road. Thus we needed both. He had us ready to go in under a half hour. The reason we got a flat was the guy at CW balanced the tires with beads but did not replace stem valves with proper valves so a bead got into valve and tire guickly deflated. Had another occurance returning to CW to get the right fix but this time it was an inside dually and we made it to CW ok. Have not had a problem since but our trip could have ended at that point had we not had a mounted spare. We certainly believe in carrying a mounted tire.
You were lucky that the wheel the spare was mounted on a wheel matching the one that was bad. It could have gone the other way and the spare would have been useless. You still would have to wait until the correct wheel was located.
Mr.Mark wrote:RLS7201 wrote:Bumpyroad wrote:RLS7201 wrote:mike brez wrote:KD4UPL wrote:
I carry a spare for sure. I can change my own tire long before any help would arrive. That's if I'm even in an area with cell phone coverage. I don't know who I would even call for help really. I assume you have to pay these roadside guys for the privilege of being able to call them. Paying for that and an overpriced replacement tire isn't for me.
Maybe on your pickup.this is a class A forum.
Maybe you don't have the expertise or physical capacity, but many of us do have the capacity to change class A tires while on the road. I for one have the capacity to change rear hub seals and front wheel bearings while on the road. So don't discount the capacity of your fellow RVers.
Richard
When I bought my various class As it was pointed out that they didn't come with a jack and there was a reason for that. that's what road service will do for me.
bumpy
Then you probably don't need a fire extinguisher either. The fire department is also road service.
If you're not qualified or just don't want to get your hands dirty, just say so. Some of us like to fend for ourselves.
Richard
Richard, fending for yourself is the best in all situations. That's great! And, I'm glad that you have the ability to lift those heavy tires and all that goes with it. Unfortunately, I have a bad back for lifting, I'll have to leave it to the professionals.
We have Michelin 365's on the front and tag axles, 315's on the drive. There is no way I could lift or maneuver that size tire. Another problem that we may have is that Michelin is the only manufacturer of the 365.
As with our other coach, I checked our air pressure before every departure and adjusted pressure as needed. I know the minute that you drive out of the RV park you could run over a nail. We were lucky. I kept the original tires until their 7.0 yr. build date.
On the new coach, we have a built-in tire monitoring system that checks air pressure and temperature. I watch it religiously.
I will replace the tires at 7 yrs. Prevost changed my front tires under warranty as there was a slight vibration that could not be corrected. Tires were determined to be out-of-round. The 365's were listed on the invoice at $1,007 each. They also gave me a three axle alignment covered under warranty.
So, hopefully, watching my tires closely will prevent a roadside replacement. I don't want to carry a spare but might think about carrying a 365 for the rarity.
MM.
2gypsies wrote:
Bigger Class A's do not come with a spare for a reason...they're heavy and big.
Richard
