CaptainCanuck's avatar
May 11, 2018
dog house covering
We are currently redoing the floors on our Southwind.Do any of the companies paint the doghouse,or do they just carpet them on the class A gasoline motorhomes.
Thanks
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to "member" issues with Open Roads Forum sites, profiles, photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
  • Put some Dynamat on the underside first to reduce the heat transfer. We took the carpet off of our doghouse cover and as of right now, it is still raw fiberglass. My intention is to install Dynamat underneath and my DW wants to do some sort of world map decoupage on it. Not sure about that, but hey....if DW's happy, EVERYBODY is happy...right?
  • I always use contact cement- apply to the back of carpet and the dog house and let both surfaces dry before installing
  • I'll say carpet it. I did mine. It was a pain. Like trying to carpet a basketball! Use a carpet with a high fiber so you can "mow" the seams. Multi color fibers help hide seams too. Carpet tape will not work. The engine heat melts the adhesive. Do it in pieces and use a heat gun to soften the carpet backing. Save the "hard parts" for last. You'll learn how to do it on the "easy parts". Leather gloves so you can work with it while still hot. Sand the old glue off and wipe clean. I "clamped" the pieces down with 1x4's scraps and screws, letting one piece dry all night before adding the next piece the next day. I used liquid nails as glue. Don't spare the glue! Some hot glue spots will help to hold it while the real glue drys. Trim the fibers with scissors to even out the seams. Watch the carpet pattern and make sure you orient it the same direction. Take a sharpie and mark arrows all over the back of the carpet so you can tell "up" from "down" after you cut it. I did mine on a table in the workshop. A/C in the shop was on! Three day job. Lots of clamps helps. Doing it in the RV on the floor would be even harder. Someone there to say "Hold this" to helps! The carpet helps with noise and heat so use carpet. If you step on your doghouses top, consider laminate flooring on the flat top side. Trust me you'll never want to do it again. If you walk on the carpet, it will wear out but if you use laminate on the top, it will last the life of the RV. Lowes or Home Depot will give you a "sample" piece free that should be enough to do the top.
  • There have been previous discussions on what to do with doghouses and most say re-carpet them. I think painting it could be an option after removing carpet adhesive and sanding and priming first. You may have more engine noise without the carpet though. One suggestion I read was that if you re-carpet find an experienced installer by calling around to carpet companies. Good luck!
  • Every Class A, gasser, I have owned has been carpeted.
