_Marc
Dec 22, 2013Explorer
Dometic Duo-therm 630035.321 heat pump will not Turn On
I have a Dometic Duo-therm 630035.321 heat pump that's acting up.
There are two units in our rig.
The front unit is fine, the rear unit will not turn on. When I set it to any functions Cool, Heat Or fan only, you can hear the click but it won't start running.I checked the main breaker and the 3 amp fuse in the unit itself and still just the click and nothing happen?
Anyone had this issue?
