Jerry_Amerson1's avatar
Apr 26, 2015
Dometic S819 Refrigerator Removal
Help!! I have to get my fridge moved out some to get to the back of my shower and replace the faucets. I have taken loose the gas line, unpluged the AC, taken the 3 screws out of the base on the vent side, and removed 8 screws around the trim on the inside. It will not budge!! It's like I'm overlooking something, and I even took a knife blade and went all around the molding on the inside in case they used some caulk there to help seal it, and it still won't budge. I've looked at a couple of videos about removing and it doesn't seem that this thing is that heavy but maybe it is.
Any help would be appreciated at this point cause I'm at a loss here!
  • Not that heavy is right.
    My guess is that there is a seal around the interior of the refer where it means the interior wall.
    Try tilting the top out, then work down with putty knife.
