Dixie_Flyer's avatar
Dixie_Flyer
Explorer II
Nov 14, 2015
Door entry code reset
I have a new to us 2007 Foretravel Nimbus that has a door entry system that is coded. No one could tell me the code when purchased but was told the hand held remotes would be all that I need. I would still like to know the code or how to reset it, any suggestions?
  • Depending on how your system is set up, your master user code will unlock the coach. Adding another digit will allow you to unlock your compartments. This is how most systems are set up. If you are waiting three minutes for the beep to sound, the system has reset and it won't work. Everything must be done within two minutes. After the four beeps, enter 1-1-1-9 and listen for the three beeps. You should hear them within 5 SECONDS. I would simply enter 1119 count to three and enter my new code. Wait another 10-15 seconds and try it.
    Here is a link to the manual....Dennis
  • Executive wrote:
    Did you get your door fixed????:h:h:h
    The key pad doesn't work. Nothing happens when you touch the numbers on the pad. I am taking it back to the dealer December 30th for some work on bedroom slide so maybe at that time they can take a look at it.
