bigwheelsturnin's avatar
Mar 10, 2014
dual hitch receivers/storage
okay...ive done an archive search..zero...so
we go fulltime...this year...sell whole kit kaboodle..hit the road.
we wanna put storage cage back of mh...also got a dinghy tow vehicle..any suggestions.?
hubby was gonna make his own..using the old steel straight up bike mount..with angle iron..
he may still..but if there's somethin out there already?
  • bigwheelsturning wrote:
    we got a crv..2006..with that spare tire on the back..which could move to the hatch floor....the door opens to the side ...we'll take a look...we used to haul bikes on a carrier for the hitch...but...we got..too old now..ha!...but that's a great idea too. thanx
    Don't know how much storage you're talking or what your toad is, but we use a hitch haul on the toad with the wheel slot accessory for bikes.....HITCH HAUL Also have a bike rack bolted on the back of that, so we can haul four bikes or move just our two back there and have the rack for hauling something picked up along the way. Thing is, the bikes are on the toad and are always with us for instant use, unless left back at the campground on purpose.
    The rear of our Wrangler is pretty much the same and the spare wheel spoke serves as a strapping place to keep the bikes or whatever from bouncing around. In fact one bike handle bar is against the spare tire. Only downfall with it all, is that the bikes or other high cargo must be removed for opening the rear gate. Still we can access it pretty good from inside the vehicle, if need be, while the bikes are still secured.
  • Dale.Traveling wrote:
    I wasn't sure if there would be a clearance issue between the tow bar and the bike rack and I didn't want to find out the hard way with a handle bar poking thru the rear cap. Preempted modification to a $50 eBay bike rack.
    There's a couple of different styles on duel receivers that should work for what you want. The Roadmaster is pretty shout and would make a good boat anchor. Other's I've seen are a bit lighter on the second receiver and are intended to bike racks or other none towing applications. The other end of the tow bar is connected to a 98 Honda Accord which sits a bit lower than the coach hitch. If I ever decide to use my CRV as a dingy I'll probably dispense with the dual receiver and hang the bikes off the back of it.
    thanks for info we plan to set cargo rack in top one for items used little like dump tank receiver on mh is high off the ground what i need to check now is tow bar mine lifts straight up and locks in position and then you drop to one side when not in use may just have to remove it when we are set up
  • yeah....i was already laffin at one of us crawlin over seat...even after layed down to retrieve somethin.
  • i can hear my wife now...####..even with laying down the seat...climbing into the rear cargo area to get something.. =-O
