holstein13
Mar 10, 2015Explorer II
Stutch wrote:
After this very dirty conversation..... I decided to get the Sewer Solution which has the 3/4" hose and uses a water just to push things along. Since it is designed for non-macerated feed it would be a good belt and suspenders approach.
Let gravity do its thing and if there is a clog, turn on the jet!
If you haven't guessed, I am trying to get away from using the 3" hose and since the MH comes with macerator toilets I'm, more than half way there!
This is the best solution. But I would not leave your black tank valve open. Eventually, waste material and especially toilet paper will build up on the bottom of your dry black tank. Just keep the gray tank valve open and keep the black closed until you dump your tanks. Run the Sewer Solution high pressure water when you dump your tanks.
38,769 PostsLatest Activity: Apr 03, 2026
