PSUJIM85's avatar
PSUJIM85
Dutchstar 4369 or 4381 question
I have been hearing that the 2016 full slide has had issues with front axel and tire overloading and also slides that sag when out. When I ask the Newmar people, there is no information on it? I was about to buy one and wanted to hear from possible current owners. I was looking at a 4369 or the 4381 floor plans.
I see the 2017 has a higher axel rating - 17,000 pounds and an optional Spartan K2 chassis as well as the Frightliner Star.
Any input would be much appreciated.
  • Blaster Man wrote:
    I know they are model numbers, that's my point. If you have a Newmar King Aire, I know immediately what you are talking about. However a DS 4369 means nothing. Other than the length, all RVs do not have model numbers...mine doesn't.
    Don't mean to drive this simple concern into the ground but the title has Dutch Star in it. Every further post mentions Newmar and Dutch Star.
  • I know they are model numbers, that's my point. If you have a Newmar King Aire, I know immediately what you are talking about. However a DS 4369 means nothing. Other than the length, all RVs do not have model numbers...mine doesn't.
    I like Dutch Stars...I just wish they would name them rather than give them numbers. Be easier for us non DS owners.
    The numbers are just the model #'s. They're all Dutch Stars.
    All RVs have model numbers.
  • They had some over loaded front axle unit in the 2002 time frame. So it is not unheard of.
  • Some of those problems came from not leveling out the coach first. Dutch Star is good coach, I think you will like it.
  • I like Dutch Stars...I just wish they would name them rather than give them numbers. Be easier for us non DS owners.
  • "PSUJIM85"...You're getting some bad info. Newmar has been selling the Dutch Star with a full wall slide for several years. If you look at most coaches, the slide edges have a lip on them that when the slide is closed, the lip covers the opening. Newmar does not use that lip so you see the opening, since it's visible (called reveal) it needs to have tighter tolerances. In 2014 and 2015, people were having some issues if they didn't get the coach level before opening the FWS, it would catch in the corner. At that time, it was recommended that you check the "reveal" before opening the slide. I've had mine for two years and never had an issue.
    In 2016, Newmar introduced their "Star" chassis that added another 3000 pounds to the coach. It included a reinforced frame and tile on the FWS floor. The slide goes all the way out and then down.
    With the weight increase, they ended up with a front axle that had very little capacity left, or slightly over, especially on the 43' coaches. Newmar was very responsive. Anyone with a 2016 43' will receive a free upgrade to a heavier axle. For 2017, they changed to new 17K axle. If you had a shorter Dutch Star, like a 40', I believe they are changing the air bags and the front rims for free on the 2016's.
    The 2017's are also coming with a better paint job.
  • Moderator: This is a duplicate post. There are more replies on the other one.
  • Lots and lots of discussion on this subject on the IRV2 Newmar owners forum
