- DrewEExplorer II
pnichols wrote:
I'm curious ... does Ford even still make available an E350 E-Series cutaway chassis for the few builders still wishing to offer some of their Class B+/C products based on the good-old E-Series chassis? How could someone even buy a U.S. sourced Class B+/C motorhome based on an "overkill" chassis anymore other than on the E450 chassis ... since IMHO the Mercedes 3500 and crop of newer U.S. OEM sourced delivery van cutaway chassis are not much "overkill" - under even a small Class B+/C.
Ford certainly still offers the E350 to motorhome builders...and others. Bear in mind that motorhomes are only a portion of the E series market; a lot of them go into things like ambulances, shuttle busses, smallish box trucks, etc. The lighter duty chassis is often a perfectly good match for some of those applications.
(Ford sells about 50,000 E series chassis per year. According to the RVIA, its members shipped a total of around 30,000 class C motorhomes in 2018, and 35,000 in 2017. It would seem that motorhomes probably account for maybe half of the E series chassis produced, at least in very rough terms.) - pnicholsExplorer II
tatest wrote:
You want GVWR 1500 to 2000 pounds more than empty weight of the RV. Much less than 1500, you tend to overload. A whole lot more than 2000 pounds, ride will be rougher unless you can load close to GVWR; it is not like air suspensions, which adjust actual spring weights to a ride height.
There are not a lot of differences between to two chassis. E-350 once had a taller rear axle ratio, and option for 5.4 V8 rather than 6.8 V10. Now, with same engine, performance is equal. E-450 gets stronger rear brakes for extra 2000-3000 pounds of capacity, and higher recommended inflation pressures for same size tires.
Maybe Ford cheapened manufacturing costs up over the last 10 years or so by building both chassis closer to the same?
Way back when we bought our small Class C on it's optional-at-the-time E450 chassis, here's what some of the differences were between the E350 and E450:
1. The E450's frame was made from stronger steel (either thicker, or a tougher grade) than that of the E350.
2. The E450's rear differential ring gear was a larger diameter than that of the E350.
3. The E450's driveshaft was a larger diameter than that of the E350.
4. The E450's brakes were hydraulically boosted, while those of the E350 were vacuum boosted.
5. The E450's brake swept areas were greater than those of the E350.
6. The E450 had both front and rear anti-sway bars, while the E350 came with only a rear anti-sway bar.
7. The E450 had a front steering damper shock - the E350 may not have (I'm not sure about this).
8. The E450's rear stance (distance between the right & left dually sets) was around 3-5 inches wider than that of the E350.
9. The E450's rear differential ratio was 4:56, while that of the E350 was 4:12.
The above are why we wanted an E450 chassis under our 24V Itasca instead of the E350. We wanted chassis overkill - betting that it would offer improved long-term reliability, durability, handling, and safety in both highway and off-highway use.
Our small E450 based Class C does not rock when we walk around inside it (due to it's stiffer suspension and dual sway bars), it's handling in high cross-winds and when big-rig trucks pass is minimally affected (due to it's stiffer suspension, dual sway sway bars, and wider rear stance), it's braking is rock solid on downgrades (due to it's larger brakes combined with it's greater engine braking from to it's rear differential ratio), and the transmission never overheats on uphill grades or when slow-speed crawling along off-highway (helped by it's rear differential ratio under both conditions). We can load up our small motorhome as we wish, with never any fear of front or rear over-loading.
We have taken most of the harsh ride away from the rear leaf springs (due to weight under-loading) by installing frequency selective damping shocks back there. The original OEM shocks in the front are still good after 71K+ miles and the ride from the E450's front coil springs has never seemed harsh (which is at least partially due to the geometry of coil springs as contrasted to that of leaf springs).
In the expedition vehicle world there are of course plenty of $$$$ heavy duty chassis choices available under small coaches, but where does one go for an affordable small rig that still has a degree of "over-builtness" in it's running gear? IMHO, the E450 under a small motorhome offers this combination. - Desert_CaptainExplorer III"This is all good information. Sounds like if you are getting a short(24Ft) MH with a full wall slide then you might need the E450 chassis for the extra weight of the slide."
An excellent observation. If you want a smallish {24' mas y menos}, Class C and plan to load, run or tow heavy then, by all means, go to the E-450 chassis. If however, you don't have slides, levelers, collect rocks or plans to tow a serious Toad you will be far better served by the E-350 chassis.
After 6 pages of interesting discussion some things simply do not change...
:B - GjacExplorer III
ron.dittmer wrote:
This is all good information. Sounds like if you are getting a short(24Ft) MH with a full wall slide then you might need the E450 chassis for the extra weight of the slide.tatest wrote:
Yep!
When loaded up (your heaviest scenario) you want to be close to your chassis GVWR. Doing so will provide a reasonably comfortable and tolerable ride. Otherwise driving on poor road surfaces, it will feel like you are driving an empty box truck with loose houseware lying on the floor, and if you are not careful, you could chip a tooth or bite your tongue. Your cup holders will be useless because your drinks will never stay in your cups....maybe your cups will not stay in the holders. In such a case with a short & light weight RV house on an E450 chassis, get the springs modified to consider your actual load to get that smoother ride. - ron_dittmerExplorer III
tatest wrote:
Yep!
When loaded up (your heaviest scenario) you want to be close to your chassis GVWR. Doing so will provide a reasonably comfortable and tolerable ride. Otherwise driving on poor road surfaces, it will feel like you are driving an empty box truck with loose houseware lying on the floor, and if you are not careful, you could chip a tooth or bite your tongue. Your cup holders will be useless because your drinks will never stay in your cups....maybe your cups will not stay in the holders. In such a case with a short & light weight RV house on an E450 chassis, get the springs modified to consider your actual load to get that smoother ride. - tatestExplorer IIYou want GVWR 1500 to 2000 pounds more than empty weight of the RV. Much less than 1500, you tend to overload. A whole lot more than 2000 pounds, ride will be rougher unless you can load close to GVWR; it is not like air suspensions, which adjust actual spring weights to a ride height.
There are not a lot of differences between to two chassis. E-350 once had a taller rear axle ratio, and option for 5.4 V8 rather than 6.8 V10. Now, with same engine, performance is equal. E-450 gets stronger rear brakes for extra 2000-3000 pounds of capacity, and higher recommended inflation pressures for same size tires. - pnicholsExplorer IILet me attempt to be more precisely precise: What our RV has in it - as originally installed by Winnebago - is a six (6) gallon water storage and delivery tank that is capable of warming the water in it to, and holding that water at, any temperature as set by it's control.
Whew ... time for a coffee and/or popcorn break ... but unfortunately I'll have to start the generator for either one or both of those. :S - DrewEExplorer II
bobndot wrote:
Lets call them water boilers.
Suburban, Atwood and tankless water boilers :B
No, surely they're hot water boilers! :p :B - bobndotExplorer IIILets call them water boilers.
Suburban, Atwood and tankless water boilers :B - Dusty_RExplorer
DrewE wrote:
Alternately, you can just realize that a hot water heater is the heater for the hot water system, just as the engine block heater is the heater for the engine block and a space heater is a heater for the space enclosed in a room.
One may equally well ask why residential hot water heating systems (not potable water heaters, but hydronic room heating) have what is generally called a "boiler" even though the water never ever reaches a boiling temperature....
The boiler for a hot water heating system can also be setup to produce steam for a steam heat system.
38,738 PostsLatest Activity: Jul 26, 2025
