Omartarpoon's avatar
Omartarpoon
E40D Tranny
Hey Guys,
Just returned from maiden voyage in 94, 28' Aerbus..
Bummer.
Transmission problems twice due to overheating, 2nd time cost me - total rebuild on the road, $3000, which I never budgeted for or could afford!
Why overheating? Is this chronic with this16,000 lb beast?
I had tranny cooler blown out and cleaned.
Installed trans temp gauge to monitor. On the way home, after about 1100 miles the temp started rising.. .....I slowed from 65 to 55, but still getting too hot, above normal.
Pulled over many times to let cool down, and now am afraid to drive it.
Any ideas?
I moved up from a 23' Winnie, which handled much better, accelerated way, way better. It was 12000 lbs. Does that 4000 lb. make that much difference?
Hell, I can only go 35 mph up hills around Colorado, and only 40, maybe 45 on big highway hills at lower elevation, which makes for an even hotter tranny.
Winnie had 454, Aerbus 460. Does Chevy rule?
Help please!
Omar
  • JcWhitney.com and summitracing.com both sell several DeRalle transmission coolers.
    Look for a flat plate design. Install it after the factory transmission cooler. Look for one rated at around 20,000 GVWR, and it should do the job. They install quickly with quick connect push on fittings and a hose clamp, with flexible lines, and inlet and outlet can be reversed to keep the lines shorter, or prevent it from kinking.
    When you click on the website above, look for or search "Transmission cooler" or DeRalle. Either should find what you are looking for. Your local auto parts store might have them too - no shipping cost either.
    Also was your engine overheating too? My 97 with a 460" engine does not overheat on the hills, and I have a digital temp gauge on the transmission too. IT normally runs around 180- 195F and on a hill might reach 215F for a short time. But that is in the normal range.
    How hot was yours getting on the drive back home?
    If the engine is also overheating, then have you heard the fan clutch kick in? That could indicate that the fan clutch is bad. This can lead to the radiator overheating, and that is where most of the transmission heat should be going - the cold side of the radiator. It has a 30,000 Btu heat exchanger built into the side tank. The stacked plate heat exchangers are a bit smaller in heat capacity.
    Fred.
  • I had a 96 Holiday Rambler 36 ft. that gave me problems with trans. overheating. I added a aftermarket trans cooler in front of rad. with electric fan. When gauge showed temp starting to rise I would turn fan on and that cooled it down to acceptable temp (180 to 210 deg).
