Olddud's avatar
Olddud
E450 1st Transmission Oil Change?
I've looked through all the manuals and searched for the answer, but to no avail. I remember being told that it is at 5 years or 60,000 miles. I am at 5 years. Any suggestions?
Also, what about 1st change of coolant?
  • My 2008 manual says 30,000 miles in RV Service. The higher mileage numbers are for vans and pickups. There is no time change specified. My 08 has 17k miles and I won't be changing it until 30k. At that time I'll put synthetic in. Synthetic in the tranny is the only thing I ever did that improved mileage - not much, but measurable.
    The manual says there is a long life coolant, good for 100k miles in vans and pickups. In RV use that is reduced to 60k. No time specified. In my 2000 V-10 coolant flush and change was every 2 years. Must be a different chemical make-up of the current fluid. The stated reason for the 2 year change on the 2000 was due to different metals: aluminum heads and steel engine block.
    I just signed up for the FMCA Rally at Madison, WI at the end of July. Hope to find a Ford engineer in one of the booths and pin down some numbers.
  • Olddud wrote:
    shum02 wrote:
    Ford Torqueshift 5 speed.
    Will take about 8 qts of Ford LV tranny fluid and a change out of the internal and external filters.
    This is a great vid.
    Torqueshift fluid and filter change
    Takes me a couple hours labor.
    Good video. That guy is a character! He mentioned 40,000 miles on the changeout of transmission fluid. I guess that is what I need to consider, and maybe not years?
    If you have 5 years on it I'd probably just change it out anyway. More than likely all is good(it is a REALLY stout tranny) The few hundred dollars it would cost would be worth it for the next 5 years.
  • BB_TX wrote:
    Would help to know the model year. Manufacturer recommendations vary depending on the year.
    It's a 2009 Ford E450 on a 2010 Itasca Cambria RV.
  • Would help to know the model year. Manufacturer recommendations vary depending on the year.
