Delonghi Micathermic Panel Heater
No fan, no noise, no flame, no glowing heating element - and you can even hang it on the wall. It is about the size and width of a flat screen TV. We have ours hung on the bedroom wall and have used it for two years. It doesn't heat the bedroom up quickly, but keeps things pretty warm once it reaches a good temp. We pretty much only use it on the low setting. It has a thermostat so it will cycle on and off to maintain temperature.
It also has removable wheels/stand so it can be placed on the floor or moved anywhere you want heat. It is very lightweight and weighs under 10 pounds.
