sd2usa2's avatar
sd2usa2
Electrical Problems! Chassis Battery / Alternator Issues.
I just got my 1st Class A RV for some future trips. It is a 2005 Four Winds Hurricane 30Q w/ Ford V10. I currently have it at my house while I fix things up and I decided to spend a night on it to give a test run. I had it plugged to a 15 amp outlet in my garage and I only used a 1200w oil heater inside to stay warm for the night. It worked fine and no breakers were tripped. But when I woke up, the chassis battery seemed to have drained. The radio wouldn't come on and the RV engine would not start or even make a whimper.
I put the chassis battery on a Battery Tender Plus 1.25amp charger and let it charge over 2 days until it was 100% charged. The RV started right up and the battery seemed ok. BUT I don't know if I just noticed this or if this is new, but while the engine is running, I am not able to use the following items together. Any one of the items work alone, but if you try a 2nd one, it won't start.
1. Headlight
2. In-dash charge plug (12v)
3. In-dash A/C
4. Radio
The order of priority seems to be 1, 2, 3, 4. If I turn on the headlight, then all others go out. If I have something plugged into the charger (phone, gps) or try to start the A/C, then the radio power goes out. Also, when the A/C is on, the fan is very weak and I can barely feel it blowing. This is regardless of whether the engine is on or not.
I am thinking that this may be an issue with the alternator, but I wanted to ask the knowledgeable gurus on here before I started tearing anything out.
I charged the battery this morning and took the Battery Tender off so I am curious to see how the battery is doing tonight. I had the chassis battery switch to the off position this morning so hopefully nothing was draining it, but I'm not sure what is going on.
Any help in the right direction would be appreciated.
