Doc Eagle wrote:
Just so happens when the "Dad" was running the very long run to tie into the city sewer line he just so happened to put in a few cleanouts along the line. The one closest to the house worked great to tie the camper into the system. I use that to keep our tanks flushed out, our house has a septic tank and just not in a good position to be able to do anything other than a pump type system.
In our area clean-outs in the line to the sewage system are pretty standard. I make the final dump at trip's end from my driveway parking spot to the clean out at the far front side of my lawn.
My macerator is permanently installed.
I use it all the time. I also have an end with standard 3" connection that I can attach if the pump fails. Works like a charm.
:C
