farmer_boots
Jun 30, 2013Explorer
Extra fan for Norcold 1200
I have the NORCXOLD 1200 series refrigerator (like so many). While camping the temperatures in the refrigerator started increasing (somewhere around 45 deg when I found it). Went outside and could not here the fans running so I removed the cover and hung an external fan to blow up through the back of the refrigerator. That worked, after a few hours you could see the temperature dropping (slow but dropping). So my assumption is something is wrong with the fans or the circuit providing power. While troubleshooting the fans started working temperatures have been in the mid to lower 30s. Maybe a bad connection, who knows but one thing for sure it will fail again when you need it the most. I have not had time to pull the refrigerator and replace the fans and thermal switch before heading out on another trip. So I am thinking about just adding a fan at the bottom of the unit until I can get it fixed. I am trying to identify a place to pick off 12 power. I see two very large wires going up the back of the refrigerator (red & black). I would think they are headed to the Fans but can't tell for sure. What else could they be feeding? My concern is their size. Is that some special insulation because of heat they may be exposed to?
Thanks
Thanks
