RvnStreib's avatar
RvnStreib
First time post: tire issues inside pass. rear
This is my first time posting and I need help.
I have on 03 4winds 31p class c MH ,2 years ago I purchased 7 new off brand tires (Mastercraft) I have now had 3 damaged tires in the inside pass. rear The tire dose not go flat it delaminates part of it. What to do now
1. larger load range tire
2. name brand tire
3. check for any thing causing damage to tire. (breaks replaced May 03)
Specs.
I am over weight
frt. axle 3780 lb - rv rate 4600 lb
rear axel 10300 lb - rv rate 9450 lb
trailer axel 5720 lb - trailer rate 7000 lb
I pull a 20 foot enclosed trailer
frt tire pressure 65lb
rear tire pressure 70-80lb
trailer tire pressure 50 lb
Curt weight distribution hitch
Question;
Is break drag enough heat to dissipate threw the rim to the tire to over inflate the tire?
Is 10 lb + - an average range for tire pressure during travel.
