dcason
Jun 06, 2019Explorer II
Flooring soft spot Jayco class C 24 foot YSLP
We bought this used and are pretty convinced that the soft spot in the floor corresponds with the LACK of metal bracing (every four feet underneath). We bought vinyl plank flooring to put down and hubby had planned to reinforce the floor. But access to reinforce that area underneath is pretty much prohibited by the gas tank. A sheet of vinyl flooring (which I have no problem with using) is probably the easiest fix without opening a whole can of worms and leave floor support (or lack of like it is).
Make a tyvex pattern which I don't mind doing and then cut the vinyl a bit bigger and then work it, float it and put trim around the edges with trim attached to the walls and floor floating under.
Does this sound like a plan? This is an rv that we use a lot and by the time we are done with it it will have a lot of miles and love on it.
Donna
Donna
