David0725's avatar
David0725
Explorer II
Jan 01, 2023
Foggy windows help please
So this Fleetwood expedition that I'm look at most the windows are fogging upI cant remember if there was a fix for that or not? If so what is the fix and who can I contact for that information? Other then these windows in about to make a offer. I appreciate any and all feed back.
  • If your are a do it yourselfer, there is a kit available online that works very well. Kit includes everything you need to do a window for 120.00. Also has a video with good clear instructions. If you have more then one window, addition supplies can be ordered for around 60.00 per window.
  • RVfogDR.com Has a shop in Searcy Arkansas.
    Phone 501 278 3015
    email: rvfogdr.com
    Does good work.
    You can call and set up an appointment
    There are videos on YOUtube that show you how to do it also.
  • rk911 wrote:
    this is a common problem. your best bet is to do a google search on
    foggy RV windows
    that should return several companies around the country that specialize in this. we had ours done at and recommend Suncoast RV in Florida.
    Suncoast is great !!
    https://suncoastdesigners.com/
  • We had a glass shop in Washington build us all new windows to replace the existing ones - but you're based in Florida............ Since they were building the frames also, we had them modify the bedroom escape window and the driver's side window. Also installed tinted glass to keep heat out. AND, they guaranteed the windows to never fog for as long we owned the MH or they'd replace them free. It's been about 6 years so far.
    Bill2005 Fleetwood Excursion 39S
  • this is a common problem. your best bet is to do a google search on
    foggy RV windows
