chag67 wrote:
I'm positive I need them. I felt the rig move at every movement of my son in the overhead bunk. I also felt the rig move at every wind gust while parked.
Plus, traveling home, my hands were cramped and sore from having to grip the steering wheel so tight.
I don't mind paying for the Hellwig sway bars but I don't want to pay for installation if I don't have to.
Upgraded sway bars help both on the road, and also on the campsite. You'll still feel people moving around in the parked coach, but no where near as much. After all, the coach is still sitting on springs and tires.
When a Ford Class C sways, that's also an un-commanded steering input, so that's part of why upgrading is so good. Don't rule out needing a front end alignment, one that increases the spec called Caster, but there's a lot that can be done short of that, to improve the drive. Cheapest, around $10, is load the coach as for a trip, people and all, and weigh it on a CAT Scale, then adjust tire pressure to the actual axle weight. Ford chassis is VERY sensitive to front tire pressure.
I helped an RV.net member install a Hellwig rear bar on a Chevy chassis, and the upgrade satisfied him with improved driving and solved his wife's annoyance about the coach bouncing when he walked around in the parked coach.
I think about all you'd need is a 1/2" drive ratchet, a few sockets, and perhaps additionally a 3/4" wrench. An 8" adjustable wrench would probably do.
Part of the reason for 1/2" drive is the amount of torque specified for some of the fasteners.
The Hellwig parts themselves are SAE wrench/socket sizes. The fasteners you have to take out and re-install to hold the sway bar brackets to the front frame and rear axle are Metric. Harbor Freight tools are just fine for a project like sway bars, and for the home tinkerer. Their basic 1/2" socket set is about $25. Stores like Lowe's and Home Depot have individual sockets you can add for a couple Metric fasteners. The auto parts chain stores, loan tools. They're usually specialized tools, but they might also loan socket sets. Basically you buy the tool. Then use it and return it for a refund.
Would you like me to go out to our E450 and get you the wrench sizes?
I think Ron.Dittmer, posted above, can link you to an RV.net thread, where he and his brother added a rear sway bar to an E350. That would be actually a little more difficult than swapping an OEM E450 bar for a Hellwig.
Wish you were closer, I'd offer to help. I've been to Maxwell, but no business out that way for the foreseeable future.
