Many, maybe most, class C's come with a hitch installed by the maker, and the limits of the hitch are often in the specs they give. Frequently the tongue weight rating is limited, presumably because of frame extensions. Heavy tongue weights are also problematic due to the long lever arm, causing a larger weight shift towards the back (and off the front axle) than there would be with less overhang.
