wtmtnhiker's avatar
wtmtnhiker
Fuel Filters change ISC Cummins
My 2005 Cummins ISC has 2 fuel filters. One has the water sensor and drain which Cummins manual says is the suction filter and the other is the pressure filter. I changed both filters but according to
Cummins I only pre filled the suction filter. The manual states to cycle the key on for 30 seconds then off for a minute and do this 3 to 4 times while the lift pump fills the pressure filter. I followed this procedure and expected the engine to easily start but instead it cranked excessively and was very hard starting. Anyone knows if this is normal? Is there another step in the procedure that I missed maybe? Seems to me that cycling the key didn't do anything to fill the other filter. It starts okay now and seems to idle alright but I won't actually hit the road with it for a few days. Likely from now on I will prime both filters.
  • Do the cycling of the key about 10 to 12 times. Makes all the difference for me.
    Listen for the fuel pump running. cycle the key after it stops - if it stops. There was a s/w update to some Cummins platforms that causes the pump to continue running rather than stop. If it continues to run, you can hear it change pitch once the filters are full.
