wtmtnhiker's avatar
wtmtnhiker
Fuel filters
Hi all,
I have a 2005 Cummins 330 ISC and will be changing out the fuel filters soon. Do I need to pre fill them or just cycle the ign switch a few times? I have read conflicting info on this and just want to be sure. I have read to fill them with Dexron trans fluid too. Thanks.
  • wtmtnhiker wrote:
    ScottG wrote:
    With an 05, you can turn the ign switch on and listen for the pump. I like to do this 5 or 6 times. The common rail system will purge the air out.
    No need to pre-fill.
    DO NOT put ATF in a CR system.
    I believe after reading comments here and doing more research that ScottG is correct. This is the procedure I will use.
    Sounds like using ATF is an old school technique that still gets used at times today needed or not. Thanks to all who replied.
    You can read many differing opinions on this but, did you actually check to see what Cummins suggests for your particular application? I highly recommend if you haven't already to login to Cummins Quickserve and register your application. Cummins has tremendous customer support available that will outline their maintenance procedure for your filters. Cummins recommends in my application for an ISL that the suction side is pre-filled while the pressure side filter is installed dry. I prefer to follow Cummins repair recommendation while I service my own coach.
    Just because someone tells me "this is how I do it and it always works" is perhaps not the best answer if you are willing to use the resources available to you.
    Good advice, I am registered with Cummins quickserve and will check it out , thanks. Don't know why I didn't think of that myself.
