jdavidsmi's avatar
jdavidsmi
Fuel Pump Replacement 2004 Fleetwood Terra V-10
It's been an ongoing issue for a while now, The engine was hard to start but once started would run great, but every bow bad then would seam to loose power but pick it right back up, and a couple for codes would be set P0171 and P0174. so i checked all the hoses, replaced the MAS, vacuum check, could not find the problem.
A couple of weeks ago on our way to the CG I lost all power and it would not pull a very small hill. i was driving about 60MPH. moved over to the side of the road and was almost stopped, suddenly I had power like nothing had happen. made it to the CG with no other problem. Again I checked everything i could see and touch, hoses, wire connectors, motor would start and run great.
We came home with no issues. But i started rechecking, still could not find a problem, This time i dug out my old fuel pressure gauge and i had only 20 PSI at the port on the fuel rail, and when the accelerator was pushed it dropped to 18 or so, I though this cannot be right, the old gauge was broken. I purchased a new gauge and fuel filter, and tried again. 21PSI now. checked the wiring and i had a full 13.3 volts at the pump. i wiggled every connection from the main panel to the pump and no change. 13.3 volts checked with three different volt meters. Decided it was a fuel pump ordered a new one and started soaking all the nuts and bolts with penetrating fluid. three days later, with new pump in hand I found i could fit the pump between the top of the tank and the bottom of the coach, great i don't have to drop the tank. put the wrench on the first nut and with very little pressure the stud snapped off. :Swoops, re sprayed everything and waited and extra day, a couple of them moved a little bit so i re-sprayed and waited again. yesterday using the method i was taught, wire brush the the threads, loosen and tighten loosen and tighten. i ended up snapping off a second stud.
:?So if your still reading after all that, My question is how do i replace the studs if possible or will i need to remove the tank and take it to a machine shop?
David
