willald's avatar
willald
Explorer II
Oct 25, 2023
full wall slideout issue - maybe
Soo, last weekend, we went camping with some friends up in the mountains. Site we got to was not very level, really had to work the jacks, blocks to get the RV level. Tried to open the (full wall) slide out, it makes some strange noises, seems like its grinding on something, but does go out, although doesn't seem like it will go all the way out - In back, its all the way out, flush, but in front, the top corner isn't all the way out, its lacking about 3/4" and that corner will go no further out.
Anyway, doesn't seem like its an issue, not feeling any cold air or seeing any daylight from the top front corner that didn't appear to go all the way out, so we decide to leave it out, go on with camping trip and not worry about it until we get back. Was lot of wind, and rain one day (Friday), and we were watching the slide edges real close to see if any rain leaked in (or wind). There was neither, all was good. Stayed very warm inside, too (was cold that weekend in the mountains). Slideout went back in just fine the day we left to come home.
Soooo, took it to RV dealer yesterday to have it checked out. Today they call me, say there is absolutely nothing wrong with the slideout, it is working just fine. Indeed, I just checked it out in person, and it is working just fine now, like new. All they did, was lube the various parts (lock arms, rack/pinion gear, etc). We are left wondering what went wrong when we were out in the mountains last weekend, that is just fine now.
We have used this rig (Newmar Baystar, see signature) extensively in the 2 years we've owned it. We use it nearly year round, average about 9 or 10 trips a year. It has never sat for more than a month or so between trips. Have had almost zero issues with it up until this (and not even sure this counts as an 'issue').
I do remember that I had a hard time getting the rig leveled this last trip, was in a hurry to do such and may have not done a very good job leveling it. Wondering if that is all it was that caused this. I do know that full wall slideouts like this can be a bit finicky about getting things level before they are operated.
Thoughts? Should I be worried, or just chalk this up to, 'Relax, and just do a better job of leveling next time'?
  • Newmar has the strongest slide system in the industry. They do have some “rules” for their slide system. First before extending slides check the vertical gap between the slide and the mh. This is called the reveal. If there is a gap (on BOTH sides), extend slides, otherwise don’t. Newmar states that most of the time (perhaps not in op’s case) the gap will be best BEFORE leveling. They don’t say when to extend, before or after leveling, just make sure you have a gap.
    I have leveled mine just to find no gap or a too close for comfort gap and de-leveled to find the gaps were good. Extended the slides, then leveled. Make sure you reverse the process in the same order.
    All the twisting to the frame and slide from the leveling probably resulted in the slide not being square, but not enough to cause damage. You were indeed lucky.
  • Nv_Guy's avatar
    Nv_Guy
    Explorer III
    As been said, your coach was "racked", try not to do that in the future. It doesn't take a lot to rack or twist an RV & they generally spring back into square once the twist is released.
  • I would assume rig was not quite level as a result the slideout was somewhat racked and would not extend fully. Once the rig is leveled properly the issue goes away.
    The takeaway is avoid the really unlevel spots when possible. Pull up on boards to get closer to level or do whatever you can if you encounter a really unlevel site. Know that the slideout will not extend properly on a really unlevel site.
    Not quite the same but I don't like it when the auto level function raises my 5'ers wheels off the ground. I do what I can to avoid the wheel raising scenario
    when I recognize a site is way out of level
  • Full wall slide have duel motors?
    I might check and see that both drive motors and screws are synced and balanced.
    Opnspaces has a good point. Could the entire structure be in a bind when this happened??
  • Sounds like the whole structure was under abnormal stress from the leveling attempt. I would probably put it in my memory as a possible issue but not to be concerned unless it happens again.
