Ok, lets catch up.
9) Remove and reseal driver's side bedroom window.
There is evidence of prior leaks.It was discovered that the kitchen window also appeared to be leaking so it was sealed as well
The excess calk will be trimmed off once it cures.
6) I want all the Rope Lights be replaced with new Rope Lights, due to burned out bulbs. Customer would like 12V Rope Lights replaced with 12V Rope Lights, and 120V Rope Lights replaced with 120V Rope Lights. If it is feasible to convert all Rope Lighting to 12V please advise customer. If it is feasible to simplify switching for Rope Lights please advise customer. Rope Lighting under steps also needs replaced. If feasible look at connecting to the same 12V source as living room lights on passenger side. All the supplies to do this job are now in hand. The first valance has been completed, but the couch on the passenger side requires the couch to be removed to get to the screws on the bottom of the valance. The coach has to come out anyway to install the new carpet.
The accent light on the valance looks very nice now that the rope light has been replaced.
8) Generator starts hard and has cut off on customer on occasion. When it shuts off, it can be restarted and runs again. Diagnose shut down issue. Perform major service on generator: Oil, filter, fuel filter, air filter, belts, and check coolant hoses to see if they need replaced. In order to get to the generator the front of the MH has to come apart.. It was suggested that
http://www.irv2.com/forums/f107/american-dream-generator-access-181770.html
"The center panel (AD logo) is easily removed with five screws on top of the panel and two larger screws in the gap between the bottom of the panel and the stainless bumper. This provides access to the front of the generator, both horns, and several wiring harnesses.
You can also get to the headlights this way, but you have to do it by feel because there are protective shields blocking access. Not quite sure what they are protecting against. Lying underneath, you can sort of see what you are doing when changing bulbs. "
This does not work on my MH
This was looked at. The top screws are easy to get to , but the bottom screws are below the top edge of the bumper. The bumper is straight with the body lines. (not me in the picture, just another expert looking at it)
The piece under the "hood" and above the bumper cannot be removed without taking the bumper off. That piece and the piece below the bumper is all one piece on my MH.
This is the back side of the picture above. I guess I could slice the piece in half and bolt the two halves to the frame work, but I am reluctant to do that
It is going to come off as I will be painting the "hood" (I really dislike the "bowtie" on the hood, it will become a straight line running straight across) and the lower valance (spoiler) so that bumper might as well come of to provide easy access to the generator for service.
15) estimate to repaint nose of coach and change white stripes (verify with customer on design change of stripes). Caledonia RV does not have a Paint shop, and had Camping World Collision shop do an estimate. That estimate was out of this world so I will do it in my basement.
The fog lights in this lower valance are useless, they through no light at all, when the switch is thrown in the cab you can not tell the difference.
I started a thread on fixing this problem, and it appears that the easiest thing to do is a blub switch, but that may not be enough
http://www.irv2.com/forums/f258/upgrades-to-factory-fog-lights-on-the-eagles-and-dreams-186948.html
Now with all the pieces off the generator is a snap to get to, along with the horns. I have a set of ship horns that I had thoughts of swapping in, but I would have to beef up the support structure to take the weight. This appears to be a project for another day. I feel the pressure of time as the February trip is creeping up on us.
Work in the cruise control continues, the control module (in the engine compartment) has been installed and the switch appears to work correctly, but in that process one of the pins on the switch pulled out, now we have a switch on order.
The interior is a mess, and will only get worst before it gets better.
There is the usual update on my web site.
http://www.leverfamilysite.com/1997_Fleetwood_American_Dream.htm
